Alignment shifting problem between premiere pro and after effects
  • July 22, 2023
  • 417 views
Hello everyone, i am facing problem while working between premiere and after effects through dynamic linking. I have replaced a compostion in premiere pro from a after effects compostion. I have made some graphs animation in after effects with proper alignment but when i see it back in premire pro, whole graph alignment is shifted towards right , ruining my alignment. while the alignments are perfect in after effects , it somehow shows slightly right shifted in premiere pro.
1. The first  screen shot is of  after effects , can see there is no gap at left side of graph alignment.
2. The Second Screen shot is of premiere pro ,where when i am seeing the graph, it just shifts rightward and leaves a gap at left side of graph alignment ,which i dont want.
Please help why the alignment is not matching when switching back to premiere pro.
Kartika Rawat
Hi there!
Sorry about the issue. We're seeing similar issues from others as well. Are you using the same version of both applications?
Let us know.
Kartika
i'm having the same issue as well. when are you gonna have a patch for this issue?
Hi there,
We're sorry about the poor experience. Please try updating the video apps (Premiere Pro, Media Encoder & After Effects) to the latest version (v23.6) & check if it's working properly. Let us know if it helps.
Sumeet
