alt+ left click
  • December 27, 2023
  • 918 views
everyone knows alt+left click u can select only 1 link/group stuff
but somehow it just reverse ?
when i left click (without alt+)it turns up that i only select only 1 sutff in link/group
how do i turn it back  ?
Correct answer Ben Insler
@金正29933309w93o You have likely turned off Linked Selection in your timeline.  Alt+left click is aware of whether Linked Selection is on or off, and performs the inverse.
Turning it back on should fix your issue.
Ben InslerCommunity ManagerCorrect answer
THX A LOT BRO U SAVED ME !!!
Christian.Z
Have you tried resetting preferences and/or reseting your workspace?
Reset your preferences by holding shift+alt (or option) when you launch Premiere
I have trouble understanding your issue.
Alt+left means Nudge Clip Selection One Frame to the Left.
Most issues are solved by Resetting Preferences.
I'm holding the alt when launching Premiere
But it just launch Premiere normal everytime
Is there any or others Resetting Preferences method ?
