ashoka16432853
Anti-Banding(Flickering) plugin in Premiere Pro
  • April 22, 2018
  • 21651 views
Hi, I am getting horizontal banding in my video footage, sample is given below. Is there any tool available in Premiere Pro to remove flickering? There is one available in
Plugins & Filters for Video: Adobe After Effects, Premiere Pro, Avid, Final Cut Pro, Resolve : Digital Anarchy . I would like to know the in-built Premiere Pro plugin for the same. Please advise.
    There are no built-in tools that do the same thing as the Flicker Free plug-in.
    there are many ways and you should try, here are some i suggest :
    1. Duplicate your clip and stack the 2 above each other, offset the video above by 1 frame, move it 1 frame forward
    and set its opacity to 50 in most cases
    2. Try to apply a 'Transform Effect' and you can see a checkmark 'use composition shutter angle' uncheck this and
    play around with its value to see if it makes any difference
    3. right click on your clip and choose 'replace with after effects composition' ... when inside after effects apply the 'Color Stabilizer'
    this will create a dynamic link, so when you apply 'Color Stabilizer' it automatically updates inside Premiere Pro
    check this link :
    Quick Trick for De-Flickering Your Video Shots - The Beat: A Blog by PremiumBeat
