Arri Amira Frame Rate metadata & Nikon Pro Res frame rate question
Hi There,
Here's a question. I have some footage shot on an Arri Amira, beautiful. The footage was shot at 50 frames. Imported into Premier its dispalays as a frame rate of 25 frames and when played in the source window it plays in slowmo, great. I also have some Nikon Z9 footage shot at 50 fps in ProRes 10 bit LOG. When I import that it shows at 50 fps but plays at normal speed in the source window. When I drag both into a 25fps sequence on the timeline the Amira footage plays in slomo but the Nikon plays at normal speed. I can slow the individual Nikon clip down to 50 percent and it then looks slomo. Why is this ? How can I watch the nikon footage in slomo in the source window ?
Also the Amira footage was recorded in ProRes 10 bit the same as the Nikon but the LUT is incorporated into the footage and is removable so you can see the original LOG appearance.. I cant see a way of doing this in the Nikon footage. Any answers ?
Thanks
Jonathan
