Audio and Video out of sync after opening previously saved project
As mentioned in the subject line, I'm having an issue with my audio and video no longer being in sync in a project I've opened from a couple weeks back.
The project contained video and audio that I syncronized manually on one time line, then I pulled clips I wanted to use from that time line and moved it to another. Now anywhere I have the clips from the "sync" time line the audio begins from the start everywhere there is a cut in the video. It's kind of tough to explain, but hopefully that makes sense. This seems to be the case for all of the audio across all time lines in the project. All of the auto save files have this same issue.
Any ideas what could be causing this? Any help would be appreciated.
Premiere, you never cease to amaze me.
