Audio bug in premiere pro. audio will mute every couple of seconds in timeline.
Hi.
I am on version 23.5 of Premiere Pro, windows 11.
I've upgraded my recording footage from 1080p to 1440p and ever since then I've had audio issue.
Everytime I let timeline play for a while, the audio will stop coming through, then go through again and keeps cutting in and out until I pause the video. It's not specific clips either! When the issue starts happening I'll just pause for a bit, start it again and it plays fine for the next 5 seconds. I have 2-3 audio tracks and sometimes only one of them will stop having audio.
I bought more RAM because I thought it was a loading issue. However, I am currently at 64G of RAM and Premiere only uses 17G at maximum when I've allowed it to use up to 50G.
This audio problem only happens during playback of the timeline. Audio is fine when the project is exported
Here are all the things I tried to fix the problem but didn't work:
-I tried to drop the playback resolution to 1/8 but that doesn't work. It still plays the video at full resolution so that's another problem.
-Like previously mentionned Premiere is allowed to use up to 50G of RAM. I have an RTX 3070 ti graphics card and a 12700k Intel CPU. I find it hard to believe it would be a hardware problem.
-I've messed with audio input and output devices.
-I watched a video that said to change certain procesing settings (cant remember which settings unfortunately) but I didn't have to change anything because my settings were already what the video said they needed to be.
I know this souldn't be happening since I dont work on huge projects. It would be a blessing if someone could help me find a solution!
