Audio drops out randomly in timeline Premiere Pro 2023
  • March 6, 2023
  • 15 replies
  • 20430 views
The audio drops out randomly in the timeline during playback.
Additionally, the video is choppy in random places, just before or just after the audio drops out. It’s almost as if Premiere is running out of memory, yet when I checked settings, it’s got 26GB allocated.
After speaking with Adobe support, with the only solution that seemed to work was to open Premiere in Intel mode and change the rendering engine to Mercury Playback Engine Software Only, rather than Mercury Playback Engine GPU Acceleration (Metal). This worked once, but the problem has since returned.
I was told that the issue is “Apple’s drivers are not able to cooperate with the latest version” of Premiere,(direct quote) and to contact Apple, but that doesn’t make sense.
Is anyone else having the same issues?
I’m running a Mac Studio, macOS Ventura, with an M1 Max and 32 GB of RAM.
Thanks!
Michael
Richard van den Boogaard
Try setting Audio Input to None in Audio Hardware preferences.
Hope this helps.
than you Richard, Ill try it.
This is also happening to me on a 2022 Mac Studio, w/ Ventura. It's incredibly frustrating. Reading through the fruitless troubleshooting below, I am even more disheartened. Clearly there's a fundamental incompatibility with this version of Premiere and this computer setup. Bummer.
Kevin-Monahan
Hi @default5b8lspejca41,
I read your case. Is it possible to get more info about your media and workflow? I hope the community can assist.
YES Im sick of this.!!! Been going on OVER 6 MONTHS!! Waveform disappears at random. Audio dropout at random. The same clip inside 3 different sequences, different projects. Clean Cache from C: drive. Reset preferences. Change project. Reveret back to older versions. I go to "software" and to "GPU". Nothing helps. I've asked tech support to help but zero response.  No wonder the mass exodus to DaVinci!!
Kevin-Monahan
Hi lymanm,
I read your note and am concerned about the experience you are having. While I'm not seeing your issue, I can understand how irritating the issue might be. Feel free to PM me a link to this file and I can take a look at it for an honest evaluation. I hope I can assist.
Kevin-Monahan
Hi again - I normally go to C: drive to clean cache. When going to Edit / Preferences / delete media cache files, why is "delete all media cache files" greyed out. Or this function the same as C: drive cache?
Hi lymanm,
Thanks for the question. It is disabled because one needs to choose File > Close All Projects and then go to the Preferences/Settings from the Home Screen; then you can delete all Media Cache (which includes media cache from the current projects - a likely candidate for corruption). An alternative is to press either the Shift or Command, keys at launch, which enables the Reset Options dialog box. Deleting Media Cache from this new function also deletes all media cache. You can either do that or delete media cache at the OS level manually. All these methods are described here. I hope the advice helps.
Kevin-Monahan
Hi Spacecadet1968,
Thanks for the message. My name is Kevin, one of the community managers here. I was looking at your case and I believe that you're having trouble with an .mp3 file in the timeline causing audio dropouts. Is that right? If so, let's look at that issue first. As a simple troubleshooting step, duplicate the source file. Then change the extension to .wav and reimport it. You can also export a .wav directly from Audition. Either way, after trying these things, report back with the results. I hope we can assist.
Hi Kevin,
Thanks for replying. I've done as you suggested, exported the .mp3 as a .wav file, and deleted the .mp3 from track 2.
Before I reimported the .wav file, I played back the video. The audio dropout is coming from Audio Track 1, the audio track that was recorded with the video.
I've included a screenshot for reference. I've also included a screenshot of the properties from the video and audio track I shot.
Michael
Kevin-Monahan
Thanks for the reply. Which camera shot this footage? That may help us figure out what's going on. I hope we can help.
Ishan Y
Hey Michael,
Welcome to the community! Sorry to hear about this. Could you let us know if you're experiencing this issue with a specific file type? Please share your source file properties (Project Panel > Right-click on source file > Properties). We're here to help.
Ishan
Hi Ishan,
Here screenshots of the two files in this project:
Video-audio is the video we shot and its accompannying audio. It's an .mp4, 4K.
Music_bed is the secondary audio. Ait's an .mp3.
Michael
