Audio filters missing (VST plugins remain on list, but not in project)
Adobe Premiere Pro Version 23.6.0 (Build 65)
Windows 11 Home 22H2
Basic steps to reproduce the problem:
When I open a project that I last opened on Thursday, two VST plugins used in the project are offline. However, they still appear in the VST list. So I can still reapply fresh instances of them. But that means I lose the settings from the audio mix I did last week. If I open older versions of the project, then only one of the two plugins are offline, not both. I don't understand how it could have happened. Nothing has changed since Thursday.
Here's the error message I get when I open the project:
Audio Filter missing: L2 Stereo
Audio Filter missing: WLM Plus Stereo
Expected result:
The project I saved opens, and I can continue working on it where I left off.
Actual result:
Project cannot be opened with all of the previous work intact. Backup versions of the project — saved on previous days — also don't open correctly. The VST plugins, however, are still on the plugin list and can be applied as they were before, as fresh instances. So they aren't missing, despite the error message.
I can find a workaround today, but it's an annoying bug that has lost a lot of time on a project that was almost finished.
