shahannneda
Audio has disappeared from the timeline
  • October 20, 2017
  • 26650 views
Over the last few hours i've been struggling because my audio tracks are playing fine but i can't edit or even see them in the timeline.
My audio is still playing fine.
Can anyone let me know what i need to do?
    Correct answer Meg The Dog
    Move you cursor so that it hovers over the bottom of track V1, near the track targeting buttons. When you see the cursor change to a line with an up and down arrow, click down and drag the line upwards to reveal the audio tracks:
    MtD
    edmund Sumner
    thanks this is really helpful
    Click on this wrench and choose Minimize All Tracks.
    Once you have all your tracks in view, you can expand the track heights of the tracks you want to work with.
    MtD
    shahannneda
    still none of the audio tracks are showing up
    Meg The DogCorrect answer
    MtD
