Audio In/Out points not visually showing on waveform in Source Monitor — still not fixed
I’m beyond frustrated.
This bug has existed for months, and it’s STILL not fixed.
Here’s the issue:
  • In the Source Monitor, when I set In and Out points on an audio clip, they do NOT show up visually on the waveform.
  • The lower bar (time ruler) shows the In/Out points correctly.
  • But the waveform itself — which used to highlight the selected area — shows NOTHING.
  • However, if I reopen an older clip that already had In/Out points saved before, the highlighted area DOES appear.
What does that mean?
The In/Out points ARE being set, but the waveform UI refuses to update.
This is clearly a visual bug with the overlay layer, not a shortcut or user issue.
I’ve tried literally everything:
  • GPU renderer → software-only mode
  • Reinstalled Premiere
  • Reset preferences
  • Deleted media cache
  • Used WAV instead of MP3
  • Updated NVIDIA Studio driver
  • Used NVIDIA Control Panel to force Premiere to use the dedicated GPU
  • Even created a new Windows user account
  • Downgraded from Premiere 2025 to 2024
  • Tested on Premiere Beta
Nothing worked.
Yet when I load an old clip with In/Out already saved, it shows the highlighted area just fine.
This proves the problem is NOT my system. It’s Adobe’s.
I'm using Windows 11 with an RTX 3060. Many others are reporting the same issue online (Reddit, Adobe Forums), and there's STILL no fix or even acknowledgment.
I'm wasting hours of time — this is not a minor annoyance.
This is a core editing feature, and it's broken.
Please escalate this. It’s unacceptable.
Sumeet_Kumar_ChoubeyCorrect answer
Adobe Employee
May 29, 2025
Hi everyone,
This issue has been fixed in the latest Premiere Pro Beta release. Would you mind trying the latest Beta to see if it helps? Please refer to this link to learn more about the Creative Cloud Beta program.
Sumeet
@Sumeet Kumar Choubey The issue is still in the version 25.3.0
caraudiofab
Just chiming in, also have the same issue. Going to try the beta now, but I find that usually the Betas are even MORE bugged.
caraudiofab
Beta solved it for me, but still, not excited about being forced to use unfinished software.
stephenf9015051
Any fix for this yet?  Also having this issue.
Adobe Employee
May 29, 2025
Hi everyone,
Sumeet
Hecubus114
Just started having this issue as well. Just updated to Premiere Pro 25.2.3, and problem persists.
Working on M1 Mac Studio with Sequoia 15.4.1
Known issue.
did you try to log out/in creative cloud app? (might be syncing issues)
can you describe your workflow?
are you in production mode?
are you working on a local machine with local drives?
what if you start a fresh new project with one single audio file to try?
