Dec 8, 2020 7:17 PM UTC
Audio issues on Premier Pro-- sound is accelerated and choppy
I'm at a loss right now and unfortuanately on a fast approaching deadline.
I'm using Premier Pro on both my desktop and laptop.  For whatever reason, sound files brought into workspace on laptop version are sped up and choppy. Both music files and the matching audio files paired with video files. This is not the case on desktop.
I worked with my IT department to make sure laptop version is completely updated, as is desktop.  So I should be working with similar functionality. The only thing I'm thinking of is that I may have unwittingly changed up some kind of audio setting that is giving me this issue.
Any suggestions for a fix?  Thanks in advance.
    Tom5CC9Correct answer
    Dec 9, 2020 10:02 PM UTC
    This step did the trick: Preferences > Audio Hardware and set Input to None. Was set to a microphone for some reason.
    Thanks so much!
    Peru Bob
    Dec 8, 2020 11:15 PM UTC
    Delete the Media Cache and Media Cache files:
    https://community.adobe.com/t5/premiere-pro/faq-how-to-clear-your-media-cache-in-30-seconds-in-premiere-pro-2020/m-p/11017257/thread-id/260446?page=1
    If that doesn't work,try resetting the preferences:
    https://community.adobe.com/t5/premiere-pro/faq-how-to-reset-trash-preferences-in-premiere-pro/td-p/8236158?page=1
    Reset a workspace
    1. Do one of the following:
    • Click the Workspace menu icon and select Reset to Saved Layout.
    • Choose Window > Workspace > Reset to Saved Layout.
    from here:
    If that doesn't work, try Preferences > Audio Hardware and set Input to None.
    If that doesn’t work, try updating or rolling back your graphics driver directly from the video card manufacturer’s site.
    If that doesn't work, try creating a new project and import the old one into it.
    Also, please help us help you:
    https://community.adobe.com/t5/premiere-pro/faq-what-information-should-i-provide-when-asking-a-question-on-this-forum/td-p/3929027?page=1
    Tom5CC9AuthorCorrect answer
    Thanks so much!
    Peru Bob
    Dec 9, 2020 11:32 PM UTC
    You're welcome.
    LinSims
    Dec 8, 2020 7:29 PM UTC
    Let me move this to the Premiere Pro forum for you, which is the appropriate forum for your question.
    The Using the Community forum is for help in using the Adobe Support Community forums, not for help with specific programs. Product questions should be posted in the associated product community.
