Audio Layers all Green Suddenly? Help please!
  • June 2, 2021
  • 2732 views
Hi guys, do any you smart people know why the audio layers are turning up as all green. I can't see the waveforms whatsoever. Everything is fine still, audio levels check out (checked gain etc). Exports are fine too.
Just the timeline isn't showing me them properly.
Appreciate any help.
Correct answer default5th4fwpunldd
For anyone else who has this problem, go to this:
 and click on show audiowaves... No idea how I turned it off, perhaps I hit a collection of keys that enabled it...
Anyway fixed now.
If you need more help, this short shows you: https://youtu.be/mJ-UHEp4he0
Used premiere for ages, never seen that setting before. Least I know now. 😐
default5th4fwpunlddAuthorCorrect answer
Anyway fixed now.
thanks for posting the solution.  Not enough people do...
