Audio meter does not display correct numbers
I'm experiencing a problem when trying to adjust the volume of a song in Premiere. I have a song that I want to be playing at -5dB. In the audio control, I've set the track to play at -5dB but when I play it, the peaks of the song display -27dB on my audio meter for some reason. I've also highlighted the track and clip, as well as placed the song in solo mode but the problem persists. Should the song be doing that when I've adjusted it to -5dB? What am I doing wrong here? 🙂
Thank you!
