Audio promlems when using wheel after CC upgrade 21/2/2017
Hi all,
When using the mouse wheel to edit the audio is not playing back properly, it sounds like a white noise clicks for each frame. I have checked with previous projects that did not have this problem and they also now have the problem. I updated premiere yesterday 20/02/2017, this problem appears to have been introduced by the upgrade. I am on 2017.0.2 v1.0.
the sound card is an integrated sound card VIA Audio HD.
Op sys = Win 10
Source Footage = .Mov
No Error Messages
Using the wheel to scroll through footage frame by frame
No other relevant software running
No 3rd party codecs
Mercury playback engine in use (open CL)
Hardware
Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz
16Gb
64Bit OS
GPU Radeion R9 200
The problem still exists with software only playback
Thanks
