smnoelke
Audio still distorted after removing denoise and reduce noise effects
  • March 2, 2022
  • 4 replies
  • 1869 views
I applied denoise and reduce noise over an entire sequence to remove background noise, but then realized that the audio in some of the clips became extremely distorted, like it was recorded underwater. I removed the effects I applied, but that didn't reverse the problem with my audio. Is there anything else I can do to fix it?
I have just used Reduce Noise before to remove background wind and it worked great.
You can try selecting  your audio and change your audio preset to "Default" and press "Clear Audio Type" to see if they helps clear the old settings. Or you could also drag the audio in from the imported files.
But try using Reduce noise on its own and see if that helps solve the wind issue.
cheers,
mark
headTrix, Inc. | Adobe Certified Training & Consulting
Richard van den Boogaard
Unless you have send all the clips through Audition, all effects should be non-destructive inside PPro. Like others have said here, have you attempted to remove cache files (Open PPro w/o opening a project > preferences > media & cache > delete cache)?
smnoelke
smnoelkeAuthor
I have, and I tried most of the other suggestions except importing everything into a new project. I guess I'll go try that and see what happens.
neil wilkes
I suspect that even though you have undone the NR, the clips are still referring to the edited versions.
If you try killing the cache, as recommended by Peru Bob, this should help matters.
NR is extremely difficult to do properly, and the longer the clip the harder it will get as you are effectively attempting to remove broadband noise across a lengthy file where the audio content can vary wildly. I would definitely recommend not doing this inside Premiere at all and instead using your DAW (Audition, Nuendo) or even a dedicated Audio Editor such as the superb iZotope Audio Editor. Audition has some very good tools for this but the best way to eliminate noise is at the capture. What type of noise are you attempting to remove, please?
smnoelke
smnoelkeAuthor
I was trying to get rid of wind noise. I've been told it's difficult to remove with just NR without degrading audio quality, so that might be part of the problem. I didn't realize just how bad it would sound though.
Peru Bob
Delete the Media Cache and Media Cache files:
https://community.adobe.com/t5/premiere-pro/faq-how-to-clear-your-media-cache-in-30-seconds-in-premiere-pro-2020/m-p/11017257/thread-id/260446?page=1
If that doesn't work, try resetting the preferences:
https://community.adobe.com/t5/premiere-pro/faq-how-to-reset-trash-preferences-in-premiere-pro/td-p/8236158?page=1
Reset a workspace
1. Do one of the following:
• Click the Workspace menu icon and select Reset to Saved Layout.
• Choose Window > Workspace > Reset to Saved Layout.
from here:
If that doesn't work, try Preferences > Audio Hardware and set Input to None.
If that doesn’t work, try updating or rolling back your graphics driver directly from the video card manufacturer’s site. If NVIDIA, do a clean installation of the latest Studio Driver (NOT the Game Driver)
If that doesn't work, try creating a new project and import the old one into it.
Also, please help us help you:
https://community.adobe.com/t5/premiere-pro/faq-what-information-should-i-provide-when-asking-a-question-on-this-forum/td-p/3929027?page=1
