Audio too low when exporting a project
- August 9, 2020
- 5 replies
- 8203 views
Hello everyone,
First time here.
I've been working with Premiere pro for a couple of years and never encounter with this problem, the thing is, when i export my project everything its correct, except for the audio that is too low on volume and quality... but the video quality is not affected, only the audio.
I recorded the vocals on Audition with a podcast mic and an antipop filter and process the audio for better quality, when i play the video on Premiere timeline is perfect, the problem comes when i export it. I tried diferent kind of settings and ways to fix it, like normalize the audio, adjusting the levels, change the audio settings, and duplicate the audio layer on the time line, wich partially work, but it's not a solution, i have already worked with diferent versions of Premiere and this has never happened to me.
Any advice will be greatly appreciated, [the export settings are below]
