gentenbettiba
audio track - a line that appears
  • January 9, 2025
  • 343 views
I have an issue with an audio track in Adobe Premiere Pro. There is a line that appears, as shown in the photo. I don’t know how to fix it to make it correct again. I don’t even understand how it appeared. Can you help me? Thank you very much
Correct answer Kevin J. Monahan Jr.
Hi @gentenbettiba,
These appear to be track keyframes, which control parameters for an entire track rather than individual clips. See, Edit keyframe graphs from a Timeline panel in the User Guide for full details. I hope the advice and link helps you.
Kevin J. Monahan Jr.Community ManagerCorrect answer
Hi @gentenbettiba,
That is showing what changes you made at those keyframes. I don't understand the problem... ?
If you want to undo effects, go to the Effects Control Panel and you'll see everything applied to the selected clip there.
Although if you applied those in the Track Mixer audio Panel, you can work there.
Or perhaps try double-clicking on the line.
Do you mean the audio level, showing on A2, with keyframes for audio levels?
gentenbettiba
yes.
