Audio track effects not working in PP2024 (v24), working fine in PP2023 (v23.6)
I just updated Premiere Pro to v24 and since that my audio track effects (external VST from Valhalla here) are not exporting. If I open the SAME project file in Premiere Pro 23.6, everything works.
When playing the video inside Premiere v24 there is no issue at all, everything works as expected, the problem only occurs when I export the video.
I tried to delete cache, doesn't help. Tried with other projects with different audio effects : none of them are exporting but playback inside Premiere works.
I'm exhausted of all these issues with Adobe Products, there is one open issue about the new Export Tab I wrote a year ago and still no news from Adobe. I have no more hope they will fix problems instead of adding new feature one day, but hey, at least if you have the same issue I have, you are not alone !
Platform : macOS Ventura (Intel)
Ben InslerCorrect answer
Following up on this thread.  This issue was resolved in Premiere Pro/Media Encoder 24.1.
Wave Digital Arts
This issue seems to be back! I've tried the 'import sequences natively' setting, which didn't work.
If you not already done so, can you try this in a new project in the lastest version? Or is this a new project? If so, try in the Beta and see if the issue persists.
Wave Digital Arts
It's not working in the latest versions of Premiere Pro and Media Encoder, but it does work in the betas. Hopefully the updated versions are released soon!
Now following up. I believe this to be a pure Adobe / Premiere problem. 24.2 (windows) seems to lose track of a lot.
Regarding the intermittent application of audio track effects in exports. I find if I nudge a setting before export that export is most of the time ok. I have to do this for at least one effect in each track chain. So, it seems on export perhaps premiere is forgetting what may have already been rendered in some situations.
This may also be happening with video. I use QT ProRes 422HQ as a render / preview codec. My exports using "use previews" and using the sequence preview codec as the export format are SLOW. Slower than realtime for a completely rendered sequence. As if things are having to be rendered. (this is a 7 minute sequence that takes 11 minutes to export as such). This is not past behavior.
Previously I mentioned Premiere getting out of sync when the bypass / power buttons were used in native (and 3rd party) audio effects. When activated in the effects window the track panel indication of the effect will be bypass and vice versa. The toggle can get our of sync. This is also new behavior.
And when exporting a sequence that has just been exported the previous export settings are not being recalled. This is new behavior.
So it seems like Premiere is forgetting a lot of little things.
Cammatador
Video Editor
Having this same issue. Audio track effects ARE NOT exporting, although they play fine "live" in sequences. These are some (but not all) VST effects. And sometimes they work and sometimes they don't. Adobe Media Encoder is not involved in my workflow (relevant to this).
Have tried a few things with varying results. Rendering effects, rendering audio effects, exporting MOV as intermediate using previews, direct export to mp4 involving on the fly re-renders. Cannot detect a rhyme or reason as when they export and when they don't. 20% success rate.
This is a high use workflow for me and was working fine. Not going to dump this on third parties. Adobe rattled something in 24.x that was working reliably. The effects exist and plan in the sequence.
I've also noticed some confusion with ALL track effects where the bypass toggle sometimes work backwards. This includes Adobe's native EQs and compressors, in addtion to third party effects.  Also started in 24.x
Presently on 24.2 / Windows / Intel i9 / ADA 5000 / 64GB ram.
Cammatador
Video Editor
@mstegner @Ben Insler
Ben InslerCommunity ManagerCorrect answer
Thanks for the detailed information, Matt!
And I think the assumption that on a trade show floor, that sometimes answers get a bit "soft" due to time/distraction things is pretty solid here. "How much time do I have to get into details?" always being a consideration.
As the essentially "effective" answer was if it doesn't hurt, and helps get something out, don't worry about it ... which for practical things has worked for most users I know of.
That it is mostly going to be an issue when you have say plugins native to Pr or Au, and not both ... that's good to know.
"I've asked about it at NAB a couple times, was just told essentially "it does stuff you don't need to know about.""
Someone, from Adobe, responded with that as an answer?  It really seems like that was not a person with enough technical background to answer that question.  Or the list of reasons was too numerous to list on the floor of a crowded Trade Show.  Having been to many of these trade shows, they are physically exhausting, and a detailed, nuanced answer is not something that can always be given.  Surely you are paraphrasing the responce though... I hope.
I can answer from the audio side of things about what it does. I'm not 100 % sure about what it does for accelerated video effects and for other video related reason, so I wont answer, or even speculate here.  I was asked above what the downsides were, not what it did.  I responded with the fact that I am unaware of downsides, maybe I should have responded that there are no downsides from the audio aspect of Premiere.
What it does:
That preference will force AME to always use Dynamic Link to open Premiere Pro projects.  The alternative is to use the native AME project importer code.
AME has all of the importers, and parsers to load and create a Premiere Pro project natively.  In the rare case that it doesn't have what it needs, like a 3rd party audio effect, AME will use Dynamic Link to get video and audio frames, and those frames from Dynamic Link version of Premiere Pro will be used for rendering the video and audio.
AME, in this case, does not contain the entire 3rd party audio effects scanning system used to enable 3rd party audio effects that Premiere and Audition have.  This is for handling edge cases mostly.  If AME has it's own set of 3rd party audio effects to maintain, a user would have to manually update the list of effects in both Premiere and AME.  If the user didn't manually do this the two lists of effects could be out of sync and a render in AME could be missing a vital 3rd party audio effect.  So, in the case where AME detects a 3rd party audio effect when opening a Premiere Pro project, AME will switch to use the Dynamic Link system and the audio effect will be part of the render.
Usually this works just fine and is seamless to you, the end user.  But, there was a recent bit of code that was refactored and this check is not working correctly.  That is why, turning off "Import Premiere Projects Natively" fixes the issue.  You are forcing AME to use the code path where 3rd party effects work correctly.
The preference was added to allow users to work around any  potential unforeseen issues, and to have a way to force Dynamic Link with Premiere projects.
Matt would have to answer that. I've never heard a full description of what that does. I've asked about it at NAB a couple times, was just told essentially "it does stuff you don't need to know about."
But it doesn't hurt to not use it? "No."
Ah well.
davef43726944
Well if it fixes problems and doesn't provide any known features...why does it exist?
Turning off "import sequences natively" is something that is often turned off to fix Pr/Me issues. I've been doing it for a decade, never had any issue because of doing so. Don't even have a clue what that does ...
No downsides that I'm aware of.  It is a bug that we hope to have fixed soon.
