Premiopolis
Audio Track Mixer - Ability to create / use Effects Panel Presets?
  • July 1, 2018
  • 1664 views
Just put in my support for this feature here: Track mixer - Add ability to save mixer states, create presets, and copy effects between slots and tracks – Adobe video …
On the off chance there is, in fact, some way to make Audio Effects presets saved to the Effects Panel available to the Audio Track Mixer panel, that would be very helpful.
RELATING TO PPRO SETTINGS MORE GENERALLY...
That there may well not be a possibility (or even if there is) it speaks to an overall challenge in the Premiere Pro settings universe: Consistency.
There is, across the board with PPro, a lack of consistency in the logic, management, file format, naming and OS-placing of settings.
ETorr published a working list of those locations here: Re: Prefs & Settings - how thorough is CC's "Sync Settings"?
For the most part they are stored under a common root directory, albeit not always.
Some settings are grouped under one file (Workspaces, Effects Panel Presets), most of the rest as individual files.
A few are stored in JSON format (Track Heights, Source Patching),
     most are XML, albeit under a variety of different extensions,
     and some can't be stored (e.g. Timeline Customization
Some of the above exceptions make a certain logical  sense (e.g. Export Presets in an AME folder), others are a little more baffling (Workspaces)
The larger point here: There's a certain lack of organic coherence in the PPRo Settings architecture that would seem to explain why the Audio Track Mixer and the Effects Panel Custom Presets don't yet coordinate around the same presets.
    Yea ... can be baffling to find all your presets, layouts, keyboard shorts, et al.
    Thanks for posting that UserVoice report! I was happy to add my comment ... though the dev. team has seen comments from me on this before. And ... um ... other things too!
    Premiopolis
    Building on ETorr list from Re: Prefs & Settings - how thorough is CC's "Sync Settings"?
    Settings SetAccess in PremiereAccess on Mac OS FinderFile ExtensionFile FormatArchitecture
    App PreferencesPremiere Pro CC > Preferences~/Documents/Adobe/Premiere Pro/[AppVersion]/Profile-[MacUser]/Adobe Premiere Pro PrefsnoneXMLAll Settings in One File
    Project SettingsFile > Project Settings[Project File]prprojXMLAll Settings in One File
    Keyboard ShortcutsPremiere CC Pro > Keyboard Shortcuts~/Documents/Adobe/Premiere Pro/[AppVersion]/Profile-[MacUser]/MackysXMLOne Setting per File
    WorkspacesWindow > Workspaces~/Documents/Adobe/Premiere Pro/[AppVersion]/Profile-[MacUser]/LayoutsxmlXMLSettings Across Multiple Files
    Sequence PresetsFile > New Sequence~/Documents/Adobe/Premiere Pro/[AppVersion]/Profile-[MacUser]/Settings/Custom/sqpresetXMLOne Setting per File
    Metadata Display PresetsBin Panel > Header > Context Menu / Metadata Panel > Hamburger Menu > Metadata Display~/Documents/Adobe/Premiere Pro/[AppVersion]/Profile-[MacUser]/Metadata Preferences/xmlXMLOne Setting per File
    Overlay SettingsSource or Program Monitor Wrench Menu > Overlay settings~/Documents/Adobe/Premiere Pro/[AppVersion]/Profile-[MacUser]/Settings/Overlay Presets/olpXMLOne Setting per File
    Timecode PresetsSource or Program Monitor Wrench Menu > Overlay settings~/Documents/Adobe/Premiere Pro/[AppVersion]/Profile-[MacUser]/Settings/Timecode Presets/tcpresetJSONOne Setting per File
    Video Audio FX PresetsEffects Panel > Presets~.Documents/Adobe/Premiere Pro/[AppVersion]/Profile-[MacUser]/Effect Presets and Custom Items.prfpsetTBDSeems XMLAll Settings in One File
    Edit to TapeEdit To Tape Panel > Save Preset~/Documents/Adobe/Premiere Pro/[AppVersion]/Profile-[MacUser]/Settings/Edit To Tape Presets/prtapeXMLOne Setting per File
    Source Patching PresetsTimeline Panel > Track Activators > Context Click~/Documents/Adobe/Premiere Pro/[AppVersion]/Profile-[MacUser]/Settings/Source Patcher Presets/sppresetJSONOne Setting per File
    Track Height PresetsTimeline Panel > Wrench Menu > Save Preset / Manage Presets~/Documents/Adobe/Premiere Pro/[AppVersion]/Profile-[MacUser]/Settings/Track Height Presets/thpresetJSONOne Setting per File
    Timeline ButtonsTimeline Panel > Track Patch/Activators > Context ClickN/A (Cannot be saved)N/AN/AN/A
    Essential SoundEssential Sound Panel~/Documents/Adobe/Premiere Pro/[AppVersion]/Profile-[MacUser]/Settings/EssentialSound/essentialsoundJSONOne Setting per File
    Export PresetsFile > Export > Media~/Documents/Adobe/Adobe/Adobe Media Encoder/[AppVersion]/Presets/eprXMLOne Setting per File
    Customize Touch BarPremiere CC Pro > Customize Touch BarN/A / not possible to save / minimally customizableN/AN/AN/A
    Oh, but you need to have the other list for locations on PC's ...
