Audio Track Mixer Panel way to zoomed in
  • November 15, 2024
  • 5 replies
  • 593 views
On Macos track mixer panel is zoomed in very wide now on macos and i cannot get it back. tried to switch workspaces or close and open the panel but the zoom settings remain. How can I change the width of the track faders on macos?
Correct answer Ali Jaber
I did some tests, the only way I found to change the tracks width was by changing the number of audio channels:
What's the resolution of your screen?
Its wqhd (2560x1440). the issue seems project-related. I opened another project and the tracks were smaller again. But there must be a way to change the width. Or does it matter which effects are loaded? Maybe if the name of the track effects is longer? I dont think so.. It must be a shortcut somehow to change it.
Ali JaberCommunity ExpertCorrect answer
