Audio Track Mixer settings not saved in Workspace
NOTE: THIS IS FOR PREMIERE PRO--for some reason the website stuck it in Photoshop and I can’t delete the post or change where it is located.
I never want to see any of the the Audio Tracks in this panel, so I hide them so I can get a very skinny view of the Mix channel just wide enough so I can see and access my Mix Plugins. No matter what I do, this does not get saved in my workspace, so my skinny panel always shows me the useless leftmost Track 1 of 4 and not the Mix Channel, so I have to either scroll, stretch it out to be 5” wide, manually go in to hide it EVERY DAMN PROJECT!!!!
    Most likely because of the scrollbar.
    You will have to make a feature request for that.
    Won't the Audio Meter do?
    chaunceycAuthor
    I really just need to access the plugins in the overall mix. I use the same stack of them 95% percent of the time, but need to check them every single time because of the long running Premiere bug that blows away my preset most of the time when I copy a sequence or auto-reframe a sequence (I have to open the plugin, reload the preset, close the plugin popup sometimes window dozens of times a day to check / re-add the preset).  Likewise, because of the long running Premiere bug where I have to redo my keyframes after auto-reframe every single time.-- it randomly moves them to another point in the timeline. WIth Adobe, I feel like I spend much of my time doing and redoing the same tasks multiple times because of all the bugs.
