Audio tracks not playing sound
  • March 4, 2024
  • 0 replies
  • 124 views
Since few weeks i have been experiencing audio track problems everytime i create a new sequence.
First and second audio tracks work perfectly fine (with the exception that every time i have to reset audio balance L/R from -100 to 0 or from 100 to 0).
The problem are 3rd and 4th audio tracks. The audio simply isnt't playing through however i can see on audio meters that the bar for the tracks (3 and 4) is visualy displaying.
Is there any possible fix for this problem or is it some bug waiting to be fixed?
