Jun 18, 2024 5:52 PM UTC
Audio volume copy paste problem
So here's the thing. In the latest premiere update, 24.5, I cant copy the audio volume and paste the attributes to all my others audio clips, which helps me maintain the same volume for all my clips. In the case of audio effects, all pastes well. Any suggestions?
May 26, 2025 9:02 PM UTC
Having the same problem in 25.2.3 (build 4).
The only workaround I've found is to select the volume section in Effect Controls and then lasso/select multiple audio clips and cmmd+v (paste) in the timeline. This seems to work so far and doesn't add a second "volume" control in Effect Controls as others have mentioned. Hope this helps until it gets fixed!
Adobe Employee
May 29, 2025 3:27 PM UTC
Hi D&Z,
We fixed a similar issue in the 25.2 release of Premiere Pro. Would you mind sharing a screen recording of the issue you are experiencing? It will help us investigate the issue properly.
Sumeet
May 30, 2025 3:40 PM UTC
I am still having the same issue, and I'm using 25.2.3, build 4.
This issue has not been fixed.
May 12, 2025 7:01 PM UTC
I've been copy/pasting attributes between clips in my timelines for many years. I can no longer do this in my current project.
I'm in version 25.2.1 and this issue has gotten out of control. I've gone through the suggested fixes, even the ones marked "correct answer," and no fix. This includes, changing workspace layout, trashing prefs, and importing my project into a fresh project.
The strange thing is that my problem seems confined (at the moment) to mono tracks only, not stereo.
Would really appreicate a fix ASAP. Thanks.
May 16, 2025 8:21 PM UTC
Update:
Started a new project. Copy/paste between mono tracks worked great.
Went back to previous project (see initial post). Copy/paste between mono tracks still not working.
I expect it to stop working in my new project eventually. We'll see...
Mar 31, 2025 8:51 PM UTC
This is now happening to me in version 25.1.0. I was able to do this earlier today, and now it's not working. I'm working on a Macbook Pro OS 15.1. The pinned reply is not a solution as I am already doing that.
Apr 1, 2025 2:10 PM UTC
That's the version I'm using as well, and my experience has been the same. It worked normally for awhile and then stopped. Very frustrating.
tidghid75271114
Mar 13, 2025 12:32 PM UTC
I have the same problem and none of the solutions below help in
Mar 13, 2025 8:15 PM UTC
What happens when you copy the clip in the timeline, and then Edit > Paste Attributes to the other clips?
Mar 13, 2025 9:10 PM UTC
Nothing. The levels on the clips that you're pasting to do not change.
Jan 7, 2025 5:46 PM UTC
I'm having the same issue. It was working fine before the last update.
G W Smith
Jan 13, 2025 5:42 PM UTC
Same issue here as well.   A workaround I found  is to adjust the clip volume in the effect control panel for the source clip, any amount, after which you can paste attribute volume to other clips.
Jan 20, 2025 3:07 PM UTC
Thanks G W.
Though not ideal, this workaround did help.
Dec 16, 2024 11:39 AM UTC
Same problem here, was working fine until I updated to 25.1 (Build 73) today and can't do it anymore
Sep 24, 2024 7:03 PM UTC
Jun 19, 2024 11:02 AM UTC
Make sure when copying the audio, only select the audio part of the clip, not the entire clip.
Then Paste Attributes will appear in the dropdown.
Matt Young14394008
Jun 19, 2024 11:06 AM UTC
Paste Attributes will appear even if you've copied an enitre clip (audio and video).
Jun 19, 2024 12:04 PM UTC
Yes I know but OP just wants audio volume. And I copied from the ECP and not the timeline (which I forgot to mention).
Jun 19, 2024 10:22 AM UTC
Could you please share a screenshot of your timeline? This will help us better understand the issue and provide more accurate assistance.
Cheers,
Paul
Feb 18, 2025 12:21 PM UTC
Feb 18, 2025 9:13 PM UTC
Rather than copy and paste the effect in the Effect Controls, copy the clip in the timeline, and then Edit > Paste Attributes to the other clips.
kglad
Jun 19, 2024 1:47 AM UTC
<"moved from cc desktop bugs">
Feb 18, 2025 12:19 PM UTC
This effects my workflow substancially as I am no longer able to simply copy Volume levels and paste across multiple tracks.
It adds a new Volume, leaving t he orginial unaffected. Almost like a Double Volume effect.
