arodon7
Sep 20, 2017 7:23 PM UTC
Audio Waveforms not showing in Multicam Clips
Did a quick search here and did Render --> Audio but I still don't see waveforms. My multicam sequence settings are multichannel mono mapped to 7 channels...trying to insert interview clips in a non-multicam standard timeline. Not sure if I have to change my audio settings on my timeline but would like to see all waveforms...I see waveforms when I drop clip as un-nested but would rather match frame back to the synced audio rather than the source audio.
Sep 20, 2017 7:25 PM UTC
I only work in stereo.  One possibility is that the multichannel is causing the weirdness.
arodon7
arodon7Author
Sep 20, 2017 7:31 PM UTC
I figured since I have multiple tracks of audio recorded (7 mono), then I would create a multicam sequence to mirror that. but maybe not?
Sep 20, 2017 7:33 PM UTC
Here's how I do it.  It solves a lot of weirdness that occurs using the auto-method.
Manual Multi-Camera Method
When you get to Step 4, select only the video track to Enable.
