Mar 18, 2022 7:48 AM UTC
Audio waveforms not showing when opening project using API call
Hi
When we use the API call app.openDocument() to open the premiere project, audio waveforms are not showing up in Premiere Pro. Same project when we open from local disc manually, it's showing the waveforms. Could you please suggest, how this can be resolved?
Bruce Bullis
Bruce BullisCorrect answer
Oct 21, 2022 2:17 PM UTC
Can you please give an update this is a problem that still exists?
Confirmed: The provided project opens with waveforms, when opened via app.openDocument(), in the current beta (23.1x48).
bbb_999
Mar 18, 2022 12:43 PM UTC
Bizarre.
What PPro version? What OS?
Can you send me a .prproj (with media), that reliably reproduces this behavior?
Confirming: PPro Preferences --> Audio --> Automatic audio waveform generation is on, yes?
emam-devAuthor
Mar 18, 2022 2:13 PM UTC
Hi Bruce,
Thank you for the quick response, we are working on a sample project to share with you. Will come back to you as soon as possible.
Premiere pro version:22.2.0
Happening in both MAC and Windows
PPro Preferences --> Audio --> Automatic audio waveform generation is on -Yes.
Thanks
Mar 28, 2022 4:47 PM UTC
Here is a link to the project. Let me know if you need any more info:
298355 - Santora's Real Estate - SantorasRE_30_0222
https://my.syncplicity.com/share/nknwvzglq81d2td/%20Santora's%20Real%20Estate%20-%20SantorasRE_30_0222%20-%201342994
pw: eMAM2022
Joëlle Bh
Mar 18, 2022 8:03 AM UTC
I wonder if clearing your preferences and trashing your media cache would help. There may be something left over in those files that isn't supposed to be there. Preferences: FAQ: How to reset (trash) preferences in Premiere Pro? Media Cache: FAQ: How to clean (delete or trash) media cache files? Let me know if this works!
emam-devAuthor
Mar 18, 2022 10:03 AM UTC
Hi
Thank you for the suggestions. We have tried the same, but still no waveforms when we open the project using API from our HTML5 panel. If we open it second time manully waveforms are coming.
We can see peack files are getting created in both occations, but for some reason, first time waveforms are not showing up in premiere.
Thanks
