deanr78548626
Auto reframe "click analyze" and doesn't work
  • October 1, 2020
  • 1233 views
I made a 4x5 auto reframe sequence and nothing reframed. I went to the "auto reframe" effect and clicked "click analyze" and nothing happens. Please help!
bradend6289696
Searched multiple articles with no success but found a solution on YouTube that worked for me. Sad that adobe support hasn't helped.
This worked for me
1. go to the clip and right click. Make sure that "scale to frame size" is not checked.
2. in effect controls, delete the re-frame effect.
3. re-add the "Auto Reframe" effect and it should hopefully work.
lemes.av
Amazing! Thanks my guy
I have the same problem. I search everywhere and I can't find any resolution documented. Please help. Thanks
lemes.av
Same for me, did you manage to fix it?
How to fix this problem. Thanks
