Automatic audio transition between clips and export
Hi!
I have a quite simple situation: I have a sequence with multiple video clips. I add a music to all the clips and I want then export each signel clip as an individual video. The thing is that for the music I want to have a fade out to silence at the end of every clip and a fade in of the music at the beginning of the next video so that each exported clip start with silence, then the music fade in and before the end the music fade out and we finish in silence. Hi have many many clips so I would like to automatize this process...
Also I would like if possible to export each single clip automatically without the need of setting in out point for each of them.
Thanks a lot!
Luca
