Dec 19, 2025 2:37 AM UTC
Automation Blocks - Copy Transform Position to Motion Position
I'm trying to alter the "Copy Auto Reframe Track To Transform" to copy the Transform Effect position to the Motion position.
But I can't figure out why "is almost equal" keeps returning false even when the values are identical.
Could anyone give me a hand?
Sample console info:
execute script
prop vals: [[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5],[0.64375001192093,0.5]]
compare [0.64375001192093,0.5] <-> [0.64375001192093,0.5] skip frame 1
Mathias Moehl
Dec 19, 2025 7:05 AM UTC
Do you get this only for your modified script or also for the original one? Can you attach your script such that we can see exactly the code producing that output?
To troubleshoot this, I would add more console output to check what exactly goes wrong. Here I added more detailed output to "is almost equal":
Dec 19, 2025 7:34 AM UTC
Thank you for your reply.
The original script is fine, it's just my version that errors.
I've attached my script, and I'll take a look at your notes to try to understand that function better.
Mathias Moehl
Dec 20, 2025 5:49 PM UTC
