Mar 7, 2024 1:15 PM UTC
Automation Blocks: interpret footage automation / audio channel mapping
I want Automation Blocks in Prem Pro to set some interpret-footage settings, but I am missing a way to map the audio channels of my imported footage. Is it possible to set the ChannelsType, ClipsNumber and do SetMappingForChannel with a Automation Blocks script?
Mathias Moehl
Mathias MoehlCorrect answer
Apr 4, 2024 8:12 AM UTC
Today we published an update of Automation Blocks, which includes a block to execute arbitrary jsx code. With this, you can now also change audio channel mappings.
See https://docs.mamoworld.com/automation-blocks/block-reference/prOther#projectitem-audio-channel-mappings
Mathias Moehl
Mar 7, 2024 1:24 PM UTC
This is not supported, yet, unfortuately.
It is already on my feature request list. I definitely plan to add it in the future, but I cannot give a good estimate, yet, when it will happen.
Mathias Moehl
m1jackson
Oct 23, 2024 7:05 PM UTC
Would this type of jsx code be able to drill into the "Interpret Footage>Color" tab in After Effects to be able to set "Preserve RGB", cause if so, now I have to learn more programming.
