jack_9558
Mar 23, 2026 5:08 PM UTC
Automation Blocks: Possible to have it set-up bins within a project
I set-up lots of premiere projects from scratch and was wondering if Automation Blocks could run a script which will set-up a custom order bin structure within in premiere projects?
Example:
00 SQs
(sub bins) 01 SYNC > 02 STRINGOUTS > 03 Current Edits > 04 Delivery
01 Rushes
02 Audio
(sub bins) Music
03 GFXS
(sub bins) Logos > Sub Styles
04 Stock
(sub bins) Artlist
    Mathias Moehl
    Mathias MoehlCorrect answer
    Jul 1, 2026 6:59 AM UTC
    Yes, this can actually be done very easily by using multiple copies of the Create Project Bin block.
    You don’t have to create the parent bins explicitly. When you create a sub-bin, the parent bin is created automatically if it doesn’t already exist.
    You also don’t need to worry about running the script multiple times, because the block will not create duplicate bins if they already exist.
    I’ve attached the script from the screenshot above. It creates exactly the bin structure you described, so you can load it directly into Automation Blocks and run it.
    Sorry for the very delayed reply. Since the forum migration, I apparently stopped receiving notifications for some Automation Blocks questions, so I’m only catching up on them now.
    Mathias Moehl
