Elwoodjblues1
Automation Blocks Renaming multiple Timelines based on Excel.
  • March 4, 2025
  • 3277 views
For a project, I regularly have to rename a lot of timelines based on a template from Excel. I used to do this manually, which takes a lot of time. Now I would like to automate this with the help of Automation Blocks. Unfortunately, I don't know what the appropriate script has to look like to realise this. Based on another script I have tried this so far as you can see on the screenshot. Unfortunately it does not work like this. What do I have to change to make it work?
Correct answer Elwoodjblues1
Maybe your issue is that yu have the "Process only selected items" checkbox checked, but actually want to process all items instead of only selected ones?
I just recorded this video to test the workflow and it worked fine for me (in the video I kepft the "process only selected items" in the inputs panel, such that you can check/uncheck it there):
OK. I have figured out where the problem was. The CSV file must be saved in CSV UTF-8 format (separated by separators). This is the only way the file can be read correctly.
Mathias Moehl
Looks almost good! Just plug the purple block inside the green one. Currently it is only executed once, after the spreadsheet has been read. If you plug it inside, it is executed many times, namely once for each row of the spreadsheet and this is what you want:
Elwoodjblues1
Thanks for the advice. It still does not work. But at least I no longer get an error message. Can I send you the script with a sample project and the Excel file? Or would the script itself be enough for you?
Mathias Moehl
