AlexxxxP
Best method for converting true 4K 4096x2160 Broadcast quality HDR to SDR - Any tips?
Does anyone have a tip for converting true 4K 4096x2160 broadcast-quality HDR to broadcast-quality SDR?
There could be a number of episodes, so if possible, I'd like to avoid too much tinkering, and apply the same process to all versions.
Any help is greatly appreciated.
PS. I'm working on a Mac, OS Monterey.
Working within the constraints of Premiere for broadcast HDR is an intriguing thing. Perhaps @dhelmly might be able to give some expert advice here? I'd sure appreciate it if he or @Karl Soule' could add advice here. Or @Jarle Leirpoll .
Knowing precisely what the broadcasters you work with require would be necessary, of course, for a definitive answer. Past that, it's only a theoretical discussion. Which can be interesting but not necessarily applicable to any one user's ... or broadcaster's ... needs. So here goes the theoretical discussion ... again, as I understand things at this time.
Premiere is built around working in HDR with either HLG or PQ formats. HLG is more to get a direct-export process, as I understand it. Where PQ is probably more suited for passing on to another worker in video post. Can I put enough qualifiers on this paragraph? lol
Getting one 'grade' that works both for HDR and SDR deliverables is kinda the Holy Grail of the colorists at this time, but ... unless your standards are pretty low, there tends to need to be an SDR trim pass. For upper level work, at least ... but then, that's probably going to be through Resolve or Baselight with a Dolby-Vision license involved. Premiere isn't capable of working in DV HDR at this time.
The normal "best practice" ... or at least, most commonly used, and most suggested ... is to do the HDR grade as the master, then do trims from that for SDR deliverables. However, I think only D-V is setup to handle two data sets in the same deliverable package.
So for HLG workflows, as I understand it ... an HLG file will be typically the only deliverable, and it relies on TVs being able to down-drop that to SDR within the TV hardware/firmware. I was following a colorist's discussion on delivering HLG, and one said his shop had tested an HLG file across several computer systems and several TVs of various eras. And wow ... was that a different image depending on the hardware involved!
Getting back to your needs, does the broadcaster utilize HLG, and is that their deliverable spec? Do they specify instead say HDR10 or HDR10+?
And if they do specify HLG, do they also take a second deliverable in SDR/Rec.709?
Adobe Employee
August 29, 2023
Part of the idea of hybrid log gamma is for one file delivering both SDR and HDR.
Karl Soule
Karl ...
Thanks for posting. And, yes ... and it's rather a variable result, depending the gear. Correct?
Any other comments you have on current HDR/SDR workflows in Premiere would be so appreciated!
The clip, sequence (working), and export color spaces need to match. Unfortunately, there isn't one specific fix for all cases.
And if you're talking ready to deliver, that always requires user attention.
As some clips, shot in a number of manufacturer log 'spaces', can be tonemapped, if they are a log image and Premiere "recognizes" and can work with. Most Sony do ok, but there's a Canon and Panny log that either aren't recognized or can be spotty.
And RAW footage needs to have the user set some controls no matter whether you're working HDR or SDR.
So ... it's all doable, just takes some knowledge of the tools and needs.
Give me more details of the media involved, I can give specific steps for each.
AlexxxxP
AlexxxxPAuthor
Hi R Neil, Thank you very much for your reply.
Just to be clear, I'm expecting a completed master/s in HDR, not the raw footage.
So, I'm just wondering if there's a way to take a finished master into Premiere (or Encoder) and make an adjustment (or set of adjustments) across the entire master that I could export as an SDR master.
I don't think it has to be 100% perfect, but if I get it to 98-99% looking OK, and within 'legal' limits for Broadcasters, then that would probably be acceptable.
Working with HDR is new to me, so if you think what I'm asking for isn't really workable, and the master/s needs to be specifically re-graded shot to shot for SDR, then I'll just have to ask the producers to arrange it as I've too much on.
It's late here in the Netherlands, so heading to bed. Thank you once again. A
Harold Silva
Maybe this video can helpU
https://www.youtube.com/watch?v=H-JFl4aRpao
Best Regards
Harold Silva B.
AlexxxxP
AlexxxxPAuthor
Thanks, Harold, I'll check it out. Appreciated.
