Best NVidea Quadro Card Control Panel settings for PPro CS6
  • November 2, 2016
  • 413 views
Hi ... I've just got a new NVidea Quadro graphics card (K620) and need advice what are the best Control Panel settings to use under "Manage 3D Settings - Program Settings (Adobe PPro)" ... I have a Intel G3240  3.10ghz running 16GB RAM and a single ultra wide screen 29inch monitor.
Many thanks in advance ... regards Paul
    Correct answer Ann Bens
    I would leave it default.
