Best Possible Quality [iPhone 7 Plus using Filmic Pro]
I'm shooting some video in Portland today and I'm looking for the BEST possible quality.
I plan on shooting with my iPhone 7 Plus using Filmic Pro. I will set the bitrate to the highest setting (for 120fps it's 50mbsp and for 4k it's 100mbps).
Here's my question.
I don't know if I should shoot in 4K today then downsize the files using Handbrake (for a constant frame rate) then edit them in Premiere Pro. Or if I should just shoot in 1080p and then run them through Handbrake (for a constant frame rate) and then edit in PrPro. Or if I should shoot in 4K, run the files through Handbrake (for a constant framerate) and do the downsizing in PrPro.
I just hate working with these files in PrPro because the 4K files are SO FREAKING LAGGY. And even the 1080p files that have been run through Handbrake are laggy and it's very hard to work with them. But if I don't get the constant framerate by utilizing Handbrake first, then the video comes out looking horrid. Maybe my Handbrake settings need a tweak so these files are usable in PrPro.
Also, working with different resolutions in PrPro seems difficult as well. I never know what my sequence settings should be. Match the 1080p files? Match the 4k files? Match the 30fps files? The 120fps files?
Thanks for any help as I head out and start shooting today. I'm thinking of shooting 4K, 30fps, and 1080p, 120fps only today. That way I get the highest quality 4K files and can figure out the HB stuff later. The 120fps files can only be shot in 1080p on my phone anyway.
