Blackmagic Intensity Pro 4K - Capture Issue with Premiere Pro CC 2022
  • February 26, 2022
  • 383 views
No video / blank frame in capture window of adobe premiere pro cc 2022 but able to capture in Blackmagic Media Express Version 3.7, Input SDI 1080 60p, Capture format Black magic MJPEG
System configuration I am using :
Processor 12th Gen Intel(R) Core(TM) i5-12400 2.50 GHz
Installed RAM 16.0 GB (15.7 GB usable)
System type 64-bit operating system Windows 10 Pro, x64-based processor
Asus Prime B660M-A D4 Motherboard with Onboard Graphics Intel (R) UHD Graphics 730
WD Blue 1 TB SN570 | NVMe M.2 SSD Storage
Corsair CV650 Power supply
I have attached screenshots for your reference,
Image 1 - Premiere Pro capture window,
Image 2 - Premiere Pro capture window with Blackmagic Capture option selected,
Image 3 - Blackmagic Capture Properties,
Image 4 - Media Express Capture window,
Image 5 - Preferences
I am looking for the solution.
gerikp
Blackmagic gear can be pretty finicky. But as someone else said, you have to make sure your capture format and the format of your source are exactly the same. Also, and I'm making an assumption here, you should not have Media Express open at the same time as Premiere Pro.
I have just captured some HD 60p footage in Premiere using my BM Decklink 4K. I just had to make sure the capture format is the same as the source.
Premiere will only capture from tape cameras over firewire.
Ann.
That is not true. Having said that are you sure the OP is capturing tape?
