Blurred Edge Transition? Help!
  • October 4, 2017
  • 509 views
Hi Adobe Forum,
I'm trying to create a type of blur transition where the text is blurred at the edges primarily and gradually reduces revealing the text. I know the latter part involves keyframes, which is easy, I need help on how to create the initial blur effect -- in Premiere, not After Effects.
I've tried "fast blur", "Gaussian blur", and all the other blurs you'd find in the "Blur & Sharpen" effects. Those effects blur the text's entire body and muddles the color (white) intensity of the text. I want the text to blur in to focus, while retaining its sharp color the whole time. Any solutions here?
I've attached a visual to give you a picture (top is "fast blur", what I DON'T want; bottom is WHAT I WANT). Fast blur is more fuzzy, whereas the one I want below is genuinely blurry. Hopefully that visual aid will help you see the difference. Thanks in advance.
Correct answer Peru Bob
If you have After Effects, check and see if there is a preset for that.
Peru Bob
