Bug with Fonts- Latest Premiere Pro 13.1 Before & After Renderinf (Color Changes with Lumetri; controls go back to default after adding shadow/backround/etc
  • July 3, 2019
  • 646 views
There is an unnerving bug in latest Premiere Pro on mac retina laptop mid 2015 when applying Lumetri color change on two different fonts and then adding different intensities of shadow, backround and etc.  It is within the TYPE/Text menu- when changing the dials of shadow/backround etc... the settings will stay correct with one title but when trying to match the same settings with text layer above it—/ the settings go back to some kind of default settings and will not stay where I put them at... J also noticed that after rendering video before exporting the actual file, the color is completelyyyy different aka a lighter shade of blue than the purple that I intended to use with both of the fonts I used.  Can the engineers please fix this?? I feel like ya’ll have a built in lut that changes everything with each render than the way it looks with colors and that has has got to stop... Caroline, somebody’ #HalP
-Pat
    Adobe Employee
    July 4, 2019
    Hi there,
    Please try to switch the Renderer to Mercury Playback Engine Software Only (FAQ: How to change the Video Renderer in Premiere Pro? ) and check if it's rendering properly. Let us know if it helps.
    Sumeet
    This shows you... the next video if not fixed will show you how the Text: Dials IE: Fill, Stroke, Backround, Shadow are not stayin at the values I set them too... once I click out of a clip and go to the next Video layer of Text!
    Color Issue with Font Titles: Adobe Premiere 13.1.2 (Build 9) - YouTube
    I'm trying to puzzle out what you're doing.
    You are using Lumetri to change the graphics color rather than the graphics color controls themselves?
