buzz sound - parasite sound in audio
  • March 27, 2022
  • 1102 views
hi everyone. When I edit this video there is a sound really high and disturbing. It is not from the video or audio file. I've been editing videos for a long time (I'm not an expert) but I didn't hear anything like that. I couldn't find a proper solution and I even dont know what cause that. If anyone knows what is that sound or know a solution, I would like to know.
Richard van den Boogaard
From what I can see, you have both an Audio Level effect going on and a Denoise Effect. Also, the track in Audio 2 is muted (M). Are there any other effects happening?
The culprit could be that you have inadvertently checked Output Noise Only in the Denoise effect. Please check this.
Joost van der Hoeven
Can you please share your system info? Like OS and version, CPU, RAM, GPU vRAM, Pr version? Thanks. Also a screen grab of your issue will be helpful.
FAQ: What information should I provide when asking a question on this forum?
https://community.adobe.com/t5/premiere-pro-discussions/faq-what-information-should-i-provide-when-asking-a-question-on-this-forum/td-p/3929027
Esra5EE7Author
iMac M1 chip. macOs Monterey and Ram is 16 gb. Sorry couldn't find other informations 😕😕
I talked with adobe assistant and he/she said run the programme with Rosetta. It seemed it worked. the weird sound was gone but today the sound is back. I don't know what else to do.
chrisw44157881
did you check if its burned into the waveform in audition in frequency view? or maybe its a corrupted video? or video/audio not supported in playback. does it make that sound in VLC?
Esra5EE7Author
No, the problem is not about the audio file. I've been working with this project for weeks and I edited without problem but 2 days ago suddenly that sound started to come frome the project (only this project.) I checked the sound but there is nothing wrong with it. I've been talking with community manager but they don't know. They didn't open the video file to see the problem - which I don't understand why they cannot open the video file.
chrisw44157881
maybe just that one clip is affected?
or is it all clips in that project?
is it random or same spot everytime?
try deleting media cache. import that same clip into a new project, does it appear?
did you say VLC can play it fine?
if it works in VLC, then try transcoding it to prores with free shutter encoder.
