annamcenger
Can I split clips into several equal parts?
  • December 1, 2018
  • 11980 views
Hi everyone, I want to split my slips in a film I'm making into equal parts. I want each one to be split every second, so that, for example, a 5-second clip becomes 5 1-second clips. Can I do this or do I have to manually split them using the scrubber?
I have Premiere Pro CC 2019 and I use it on a MacBook pro
dzgnr89
Came here at this four year old thread, with same requirement . Cutting a video into equal parts. How to do it in Premiere Pro 2022?
Peru Bob
It has to be done manually.
dzgnr89
Yes. That's what I've been doing. Moving the slider at regular intervals and cutting the video at those locations.
What's the main reason for doing that ? as Rodney said this feature is not here yet, but maybe we can help
with other ideas if we get what exactly you are trying to achieve?
I have the same question. In my case I have to split the clip in 2:20 min each, that is the maximum por twitter video.
I don't there is a automatic function yet to do that. The time in timeline gives info on min, seconds, frames, and it shouldn't be too hard to just cut every SECOND or whatever. I guess you could put in a feature request for that ??
