Can no longer decode AC3 audio from MTS Video cameras
  • November 17, 2017
  • 4 replies
  • 5820 views
Since removing AC3 support from CC 2018 I am no longer to read/decode audio from footage from my Canon XA10.
I understand not being able to encode in AC3 but don't understand why I can't decode video footage from MTS files.
I am on the latest version of Mac OS X (High Sierra) and latest CC 2018 but still can't get it to work?
    Correct answer Squirrel Face
    I don't believe Michael meant any harm by his statement. Just some advice that you can take or leave. Personally, I do not begin any major new projects until the version has seen at least one bug fix. I do hope we can help you solve your issue, though.
    Cheers,
    One of my new projects is using 360 VR video, feature only in CC 2018. You (Adobe) advertised this with great fanfare so it's not like I'm unnecessarily updating. I tried to raise this issue in a thread because I want to use 2018 (hey I am paying for it) and I thought telling you about it here might help.
    Honestly everytime over last decade that I've tried to lookup help on these forums they're just full of people going off topic or unwarranted arrogance from the 'pros' who have absolutely nothing meaningful to contribute other than bitter retorts, it's very frustrating to trawl through when you're looking for a solution not 'banter'. I'm trying to raise a genuine issue and being told "well durrr it's not updated yet", I know that but if I don't report this issue how do you know to fix it in the first place? Wish I hadn't of bothered. I've given up on this thread, no further response required and I've marked as assumed answered.
    Here's an some actual meaningful information for anyone searching these threads with similar issue with AVCHD:
    After over an hour of Adobe remote/looking into the issue they've tried everything (checking permissions, checking QT codecs, checking adobe preferences, trying diff MTS files) and concluded that indeed Premiere CC 2018 can't read audio from my Canon XA series / AVCHD / AC3. I am waiting for dev team to follow it up over next few days but finally progress in that they've acknowledged the issue and have escalated it for me.
    I can suggest a page on your topic: https://mac.eltima.com/ac3-audio-player.html
    Exactly the same problem for me my friend, is it not just you, i also know many others with the same problem. I have gone to the extreme of rebooting my whole system. I am also on high sierra. Nobody seems to have any idea on how to fix the problem.
    Don't worry dude, you're in good company. It's been escalated for me so at least we know they know now - that's all I wanted. Progress!
    Kevin-Monahan
    Hi SquirrelFace,
    Have you tried all this with a brand new project rather than an updated one? Or have you tried that? It's the one troubleshooting step I have not heard you try yet.
    Hi Kevin
    This is with a new project file and with existing project files.
    Thanks.
    Kevin-Monahan
    Can you upload a sample file I can test with?
    Relocate the files, re-link and try again.
    Unfortunately that doesn't make any difference.
    You can even make a brand new project file and import footage and it still refuses to recognise MTS audio.
    Even relinking I don't believe that will work as I believe the problem is that AC3 support has been removed which appears to have affected ability for me to decode MTS files. Only CC 2017 still works.
    Hi Ann. These are basics steps that I tried straight away multiple times and made no difference I'm afraid. Even if changing location helped we wouldn't be a realistic solution as we have 3-4 years of file paths in use that would mess up all our workflows.
    Why do users of Premiere Pro CC feel the need to update or upgrade immediately.  There are always bug reports.  If the version you have is working properly and the new updates or upgrade do not add anything that you need, then don't!!!!!!!!
