Can Premiere Pro import shotmarkers from Sony PMW-350?
  • February 3, 2020
  • 347 views
I am trying to record, use shotmarkers to verify good takes and then import directly into Premiere Pro without using Catalyst Browse.  The video can be import but the shotmarkers don't appear.  Is there anything I can do to change that issue?
Thank you.
Upload a sample for us to check out, Deron.
Thanks.
Was there an answer for this? I am trying to import shot markers stored on .xml files that ride with my .mxf clips. Shot on Sony FS7. I have uploaded the .xml
Would really really help with the doc edit!
