Oct 19, 2023 11:59 AM UTC
Can't Copy and Paste Sequences in Project Bin (Premiere Pro)
Ever since the 2024 update of Premiere Pro, I can't copy and paste sequences.
I've gone to Edit > Paste and for some reason 'paste' is greyed out. I've tried the shortcuts and they produced no results either. I'm able to make a new sequence and paste items into that sequence but I can't copy and paste the sequence itself.
Is this a bug or am I missing something?
Adobe Premiere Pro 24.0.0
Mac OS 14.0
I've attached a video as a reference.
Peru Bob
Peru BobCorrect answer
Oct 19, 2023 2:32 PM UTC
Right click and choose Duplicate instead of copy and paste.
Oct 19, 2023 2:20 PM UTC
Recently updated as well.
1. I repeated your steps, works on my system. (OS. 13.4 (22F66)
2. Did you do a complete reboot (seriously it's annoying but try it.)
Also have you tried selecting duplicate to see if that works?
This stuff should never be an issue, very annoying.
JND98Author
Oct 23, 2023 11:46 AM UTC
I tried doing the same steps in a different project and it only worked for certain sequences. I checked if the sequences were different in any way and I couldn't find any differences... So strange.
I haven't tried a full system reboot, maybe that might solve it. Although, I've chosen to use the duplicate function instead. I didn't actually know you could do that lol, much easier!
kglad
Oct 19, 2023 1:25 PM UTC
<"moved from using the community bugs">
