Can't get plugins to work in Premiere Pro v25.1
Hi
I can't seem to get plug-ins to work on V25.1 - I use atomX for transition & text packages (PremiereGal & whiterecord). I'm able to install the packages but applying them to sequences does not work.
I have uninstalled and re-installed both Premiere and the plug-ins but no success.
I am using a mac, grateful for any advice.
Thanks
