theok8577996
CC2024 versions not shown with fresh new installation?
I noticed with new fresh system install that Creative Suite does not cc2024 version in the app.
Only cc2023.6 and cc2025.1 with Premiere Pro.
steps to repro,
get a new install of windows
install creative cloud app
Ce sujet a été fermé aux réponses.
2 commentaires
Most likely, 2024 is not compatible either.
And therefore not showing in the CC desktop app, as 25.1 is the most current one.
theok8577996
Intel CPU 37xx did show the same thing.
Intel CPU 47xx and higher show all versions.
kglad
reset the cc desktop app by making sure it's in the foreground, then press:
Win: Ctrl + Alt + R
Mac: Cmd + Opt + R
if that fails, repair per https://helpx.adobe.com/download-install/kb/creative-cloud-install-stuck.html
if that fails and you have windows, open your control panel > add/remove programs > cc desktop app > repair
if that fails, uninstall using the correct uninstaller from https://helpx.adobe.com/creative-cloud/help/uninstall-creative-cloud-desktop-app.html#sa_src=web-messaging and then reinstall using*
if that fails, do a clean cc install carefully following each applicable step:
uninstall every cc app including preferences per https://helpx.adobe.com/creative-cloud/help/uninstall-remove-app.html
then uninstall the cc desktop app, again using the correct uninstaller per https://helpx.adobe.com/creative-cloud/help/uninstall-creative-cloud-desktop-app.html#sa_src=web-messaging
clean your computer of cc files per http://www.adobe.com/support/contact/cscleanertool.html
check for, and if available, update your os
if windows is your os, repair all ms visual c++ versions that can be repaired (use google if you don't know how to do this)
if windows is your os update your ms visual c++, if it can be updated (use google if you don't know how to do this)
restart your computer (don't skip this)
reinstall the cc desktop app using the "alternative download links" at the bottom of the page at https://helpx.adobe.com/download-install/kb/creative-cloud-desktop-app-download.html
use the desktop app to install your cc programs/trials>
if that fails, you probably have a corrupt user account. google your os and how to create a new one.
theok8577996
extra info, I installed on old hardware, Intel I7 2600K CPU with GTX 1080 and Win10 (22H2)
reset of Creative Cloud did not help.
kglad
did you proceed to repair?
