Change Resolution of Premiere Project?
  • January 10, 2012
  • 4 replies
  • 334473 views
I've been editing a project at a draft resolution of 864x486.  .  The final res is going to be higher.
In the video settings for a given sequence, the resolution is not editable, nor do I see way to change res in the project settings.
Is there a way to change the res of my current project?
Thanks much.
Correct answer caroline_edits
Hey everybody! We created a short video tutorial to cover this information. I've found it's more helpful when you can see the interface! Only 45 seconds, check it out.
Hope this helps!
Caroline
caroline_edits
caroline_editsCommunity ManagerCorrect answer
Hope this helps!
Caroline
None of those windows appear for me and it shrinks the video
In the current release of Creative Cloud, you can change the resolution of a project after you've put assets on the timeline by choosing "Sequence" --> "Sequence Settings" and adjusting the frame size to the desired resolution. Note that this will not resize your assets to the new frame size. The "Scale" tool under "Effect Controls" --> "fx" (dropdown) is useful for quickly resizing, though in a project like the one mentioned above at 864 x 486 it is unlikely those assets would scale well on a frame of '1080p' (1920*1080), for example.
Sequence Settings is greyed out for me so I can't click it
This feature is only possible in newer versions.
You have to set the editing mode to custom in order to change parameters.
Stephen_Spider
There is no draft resolution presets in premiere. There is only the dynamic preview quality settings that can be adjusted in the source and program monitor.
You can copy all of your clips and paste them into a sequence that is the proper size, then make adjustments to individual media assets accordingly. Or you can drop your "draft sequence" in a proper format sequence and see what happens, it won't be good I'm afraid.
Harm_Millaard
Not in your current sequence. You need to create a new sequence with the proper pixel dimensions or create a new project.
voxLAuthor
Thanks for your quick reply.
Is there any way to copy all the edits into the higher res Sequence?  Maybe open in AE, change the res, and export back to Premiere?
