Changing speed with Optical Flow - Kind of realtime...
I use 1080p50 footage, XAVC HD, long-gop, from a Sony X70 camera. If i change the speed of a clip and change the Time Interpolation to Optical Flow i get a red render bar abowe the clip and the playback stutters unless i render the clip.
Yesterday i noticed that if i drop Lumetri Color to the clip the render bar changes from red to yellow and the clip plays back smooth as butter when the speed has been changed using Optical Flow.
The question i have is if there is another way to get clips with speed changes using Optical Flow play back in real time without having to add, for the moment, unnecessary Lumetri Color? It seems odd that in order to get realtime playback one are forced to drop Lumetri Color on it.
Computer:
HP Z440
Processor: Intel E5-1650v3
RAM: 64 GB
Graphic: Nvidia Titan X Pascal
HDD: PCIe SSD (Intel 750 series 1.2 TB)
