"Click Analyze to begin" won't go away, even after analyzed.
  • January 14, 2014
  • 35 replies
  • 174684 views
I'm working on a project right now in Premiere Pro CS6 and for some reason the "click analyze to begin" blue bar for warp stabilizer will not go away, even after it has been analyzed. I tried exporting it thinking that it would go away, but nope, it seems to be baked into the image. I need to get this project turned in to a client as soon as possible. Is there any way to fix this without have to replace/re-link some of the footage?
Thank you
Correct answer Tish06
Right click-REMOVE ATTRIBUTES worked for me.
Go to "Effect Controls" and you'll find the "Analyze" button.
Try toggling visibility for all tracks above the one that won't analyze, then re-enable them when it's done. Worked for me, and didn't have to shuffle around or nest any clips.
This work around is not working for me.
I found another work around. If tips from above do not work just move the clip you want to stabilize to a different location in the timeline (could be right next to it) and then click analyze
shaunvns
I've come across this a few times. The way I work around it is to ensure that there are no layers of video above the clip you're stabilising. So if you have your interview (for example) that needs to be stabilised and you have some B-Roll above that video on V2, just cut the interview clip and trash the parts under the B-Roll, you don't need it there anyway.
Snakedogman
Thanks for that. I was having the same issue just now and your suggestion worked for me. I just copied the affected clip to some empty bit of the timeline, ran the analyzer, and copied it back into place.
Have you tried removing and reapplying the effect?
Yes I've tried that.
OK.
Have you tried nesting that clip, and applying the effect to the nest instead?
