Jun 12, 2026 8:42 AM UTC
Clips will not create Multi-Cam Source Sequence from Audio synchronize point
All my clips and sound files have synched via the Multi Camera Source Sequence Method apart from 2 and as a newbie I am uncertain whether to just merge these other two clips so i can get on with changing everything to Proxys and editing...can anyone advise please? What would be the best solution?
    Jun 12, 2026 3:16 PM UTC
    Do those 2 clips need to be part of the multicam clips you’ve created? If so you can open a Multi Camera Source Sequence in the timeline (right click on it and the option is there) and add in new angles to that multicam timeline. It’ll update everywhere the mulitcam clip was used.
