Robert The Editor
Color Correction Help - Matching Constantly Changing Exposure
  • February 27, 2018
  • 256 views
Hi there, I am a video editor and have recently have had some issues matching shots on two different cameras with Lumetri. The projects I've been editing recently have been just shot quickly and so the camera man is constantly adjusting their exposure throughout segments. This forces me to adjust the color correction as I go. Does anyone have any advice on order of operations for matching two shots that were shot on different cameras that have different color settings and exposures throughout? I usually adjust exposure first but have learned conflicting information on whether I should adjust the Gamma first by using either the curves or Mids slider in the color wheel or to just use the "exposure" slider. I also have learned conflicting info on whether I should white balance before or after exposure adjustments. When I color correct, I usually use several layers of Lumetri...One for Exposure & contrast, another for white balance & saturation, and then last for color balance, etc. My two questions are:
1) If a single camera within a scene is constantly changing their exposure, do I have to re-do the entire color correction or can I copy and paste the color correction from earlier in the timeline, and if so, what exactly should I be adjusting that will closely mimic the camera's lens and match the exposure & color of the previous shot and in what order?
2) For matching a two-camera shoot where one shot is exposed well and the other underexposed, would the answer to my first question above apply as well or should I take a different approach? I attached an image that contains an example of two shots that I recently worked on. One shot is underexposed. The image contains both shots and corresponding vector scopes.
Thanks for your help!
Oh my ... so you've been provided some glorious files to edit. Yuck!
First thing you have to do when working with multiple camera shoots is get everything to "neutral". So when you go clip to clip, they look like un-corrected but decently shot clips and you don't really notice camera differences. This ain't to get to pretty, but to get to a decent starting point.
I agree with the thinking that getting the tonality balanced really should be done first. I've found that going to the Creative tab, zeroing Saturation, then going back to the Basic tab to work at tonal things is great, as you can turn that tab's correction on/off to check what your work has done to the original clip. I've got a blog post showing exactly what the basic tab's tonal controls do, some of which may not be what you expect here. And it may help speed you along in your work.
Lumetri Basic Tab: What do the tonal controls really do? – rNeilphotog
The biggest problem with tonal work in the Basic tab is that nothing really works on the bottom end in a linear fashion. "Blacks" is a sort of wag-the-tail effect, mainly working from a couple points above the 'current' black area at first touch up to the 20 value at full force. But it does very little to the values above it, so it does some odd stretching and/or compression to the values from about 50 on down.
It takes working Shadows and Blacks together to accomplish something fairly smooth down there.
Exposure ... is an odd tool. Taking it "up" to positive values is like a curves adjustment lifting from about the 70 point, but doesn't do anything on black point and can if pushed enough force highlights up to clipping. But taking Exposure down is clearly a pure "gain" control, and exactly the same as the Whites control (also a pure "gain" control) ... it drops the white point, and everything else in a straight line to the black point. While for many things Exposure for me isn't that useful, for your work, you might find it very useful.
Whites is as noted above a pure and easy to anticipate (therefore use!) gain tool. Shadows & Highlights both extend WAY past what you might think, so if you move one, you really probably need to work both.
Once you figure out how to use it, it's pretty decent though. And a BIG note ... if you're going to get much color work to do, you need to get at least a Tangent Ripple or a Palette tool. Having some sort of control surface properly set up gives you both faster work and better work, as when working two controls simultaneously, you see mid-corrections you can't see working one control at a time. It would at least double your speed in the first month. After that, you'd be at least four times faster in color work.
Next ... the White Balance section in the Basic tab only balances the whites & upper highlights. Watch the Parade RGB controls. Moving Temp changes the balance of the top of the red against blue channels, does not touch green. Tint changes the red/blue tops against the green top. Nothing happens in the shadows, maybe a small change in the mids, more as you get into the highlights.
If your clips are shot at different WB settings in-cam, this doesn't clean that up. So ... skip 'em.
After you've done your tonal work in the Basic tab, go to Creative, zero the Sat slider to get your color back, then use the Shadow 'tint' control to effectively neutralize the shadows by finding a major structure (shape) in the deep shadows that is there on all three Parade RGB traces, and working that Shadow Tint tool until the shapes line up across the bottom. Do the same in the Highlight Tint tool, and you've probably neutralized your whole clip.
Now use the Saturation and Vibrance controls to get your color amounts looking ... you guessed it, "normal" or neutral. Maybe add sharpness to one cam to match the look of the other at need. You should by this time be fairly neutral.
I'll have another series of posts on my recent changes in my neutralization work in Lumetri up over the next few days.
