Converting Luts and Looks Into Presets
  • January 22, 2022
  • 5498 views
Hello Everyone.
I have many Custom Luts, and I  noticed, every time I want to add a Luts to my Footage, I have to Browse and search for the Luts. So after applying the Luts to my Footage, I saved It as a Preset, and later instead of Looking for the Luts, I just Drag and Drop the Preset Into my footage. Is that Ok?
NOTE: I never add a Luts, or any Effects directly Into my Footage, I always use Adjustment Layers, so I can adjust the Opacity. For Example One Adjustment layer for Luts, another Adjustment For Color Correction, and so on. Also, I never depend on Luts only. I noticed many times, like shooting WIDE DR, my Footage looks better when I Color Correct Manually, rather depending on a Luts.
Thanks.
Correct answer R Neil Haugen
First, if you're LUTs are stored in the proper places,  you can easily use the dropdown lists in the Basic and Creative tab without needing to scan folders each time. I'm on a tablet so don't have the chart image available at the moment.
But it's something like Program Files/Adobe/Common/LUTs, and then add Technical and Creative folders to the LUTs folder. Park your LUTs there. The ones in the Technical folder will appear in the Basic tab drop-down list, Creative folders in the Creative tab.
Now, adding LUTs to a preset works beautifully also. Especially as you can have a lot of work already setup across the full Lumetri instance, and can even drop it on clips in a bin, so it gets applied to them as a Source setting, shown on the Source tab in the Effects Control Panel.
Most colorists use a lot of LUTs for specific things technically, but they tend to make their own. And they don't use them for 'grading' but conversions. It's faster to grade manually than pore through a bunch of LUTs testing out what they look like.
R Neil HaugenCorrect answer
Mr. Neil.
This is the Where I have Installed my Custom LUTS. This is from Adobe Site:
Thanks
The .look files can only be used in the Creative tab. The .cube files can be used in both places.
And I rarely use the Basic tab LUT slot as there's no way to trim the clip's exposure/contrast/saturation to fit through the LUT.
Mr. Neil.
You are the Best
Thank you very much
